[OpenLayers-Dev] bug with multiple VirtualEarth layers of the same name
Brandin L Claar brandin.claar at gmail.com
Wed Mar 4 18:23:32 EST 2009
Hi.
It appears as if the VirtualEarth implementation in OpenLayers uses the
supplied name as a div id.  This will create a problem if you are using
multiple instances of the control with the same layer names.  I am
providing the attached trivial patch as a potential solution.
-brandin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090304/88b10853/OpenLayers-VEdiv_id.bin
More information about the Dev mailing list
