[OpenLayers-Dev] ESRI and OpenLayers
Christopher Schmidt crschmidt at metacarta.com
Tue Mar 10 21:16:19 EDT 2009
On Tue, Mar 10, 2009 at 01:03:44PM -0600, Tim Schaub wrote:
> Hey-
> David Zwarg wrote:
> > Greetings community,
> > One thing to note for the ArcIMS and ArcXML patches: they are a best
> > effort to implement the most commonly used functions in ArcXML.  This
> > includes get image and get feature requests.
> > Anyone who's looked at the ArcXML specification knows that it's very
> > thorough, and supports a myriad of operations.  The ArcXML support in
> > the patch mentioned implements image requests and feature requests.
> > However, there are limits to what is implemented.  The entire ArcXML
> > schema is not replicated in the ArcXML patch, so it's not a complete
> > port.  As with most projects, the current patch satisfies the business
> > need that I have with the resources that I have.
> > I am willing and able to be the custodian of that component, but will
> > need more feedback from users of the ArcIMS layer for advanced
> > operations (geocoding, projection (have you heard of this proj4js
> > library?), etc.).
> Count this as a tentative offer to help review stuff and get it in the
> trunk.  We (OpenGeo) are interested in Arc* support in OpenLayers as well.
> I'll follow up on the ticket(s) when we've got the back end stuff set up
> for testing.
I'm taking on ArcIMS at the moment; I should have a reviewed patch
within the next day.
> Tim
> > Thanks,
> > z
> > On Sun, Mar 8, 2009 at 10:03 AM, carls <carlshe at 163.com
> > <mailto:carlshe at 163.com>> wrote:
> >     I had tested
> >     'root/sandbox/dzwarg/openlayers/lib/OpenLayers/Layer/ArcIMS.js'
> >     and 'root/sandbox/dzwarg/openlayers/lib/OpenLayers/Format/ArcXML.js'
> >     with
> >     OL2.7. It works well.
> >     I hope and would like to see the support of ArcIMS in OL2.8, if
> >     possible.
> >     Thanks.
> >     Christopher Schmidt-2 wrote:
> >      > Eric,
> >      > Your email led me into a response that is really far more
> >     appropriate to
> >      > the entire dev list in my opinion. ESRI and OpenLayers is a
> >     particularly
> >      > large hole in the library support, and I wanted to really get
> >     down a lot
> >      > of my thoughts on why this is. Please take all this with a large
> >     grain
> >      > of salt as being my personal point of view... but perhaps not an
> >      > entirely-inaccurate one, given my level of involvement in the
> >     project.
> >      > On Mon, Mar 02, 2009 at 04:27:21PM -0700, Eric Wolf wrote:
> >      >> Christopher,
> >      >> I hate to open old wounds, but I'm preparing a presentation centered
> >      >> around generating a tile cache consumable by OpenLayers but based on
> >      >> an ArcGIS map layout. I've tried some different configurations:
> >      > So, I want to start off by saying this: No existing OpenLayers core
> >      > contributor has, in any major way, a personal or professional
> >     motivation
> >      > towards supporting ESRI's web services, so far as I am aware.  This
> >      > includes the OpenGeo community (generally speaking, tightly
> >     coupled with
> >      > GeoServer), the Camptocamp group (which works almost exclusively
> >     outside
> >      > the realm of ESRI, as far as I've observed: possibly motivated by
> >      > Europe's lack of proprietary buy-in, hooray), or the DM Solutions
> >      > (primarily around MapGuide, and MapServer) or MapGears (primarily
> >     around
> >      > MapServer) contributors. I expect that if you came with $$ to any of
> >      > these groups, they would be likely to be able to help you, but
> >     it's not
> >      > so common of a problem to make it worthwhile for them to spend time
> >      > maintaining ESRI-specific code without a customer asking for it.
> >      > With that in mind, almost all work on ESRI-related developments
> >     thus far
> >      > has been by non-core contributors to the project, and OpenLayers has,
> >      > in some cases, not had a great track record with non-core
> >     contributors
> >      > of content doing the work to get their code in trunk.
> >      > The ESRI AGS code developed thus far has been prey to this: several
> >      > people have used it, but not:
> >      >  * Documented it
> >      >  * Tested it
> >      >  * Created examples for it
> >      > As such, the code is not something that the OpenLayers community can
> >      > support without a strong leader stepping up and taking on the task on
> >      > the code.
> >      > Some counter-examples to this are:
> >      >  * The recently committed ArcGIS 9.3 REST API layer.
> >      >  * The in-review ESRI ArcXML layer.
> >      > Both of these sets of code have had committed developers who have
> >      > written tests, provided documented examples, etc. in clean, well-laid
> >      > out patches.
> >      > Based on your problem description on the mailing list --
> >     something you
> >      > neglected to include in this email, which makes it difficult to
> >     respond
> >      > to precisely -- I can not describe what the best solution is for you,
> >      > based on my personal knowledge. I don't use any ESRI products or
> >      > anything else.
> >      > Though I don't know if it's the best thing for your use case, I
> >     do feel
> >      > that it would be beneficial to the OpenLayers community to have
> >     access
> >      > to ESRI's map caches. Cached map tiles are clearly much faster than
> >      > non-cached map tiles, and the recent developments of ESRI's -- making
> >      > available, for example, sampleserver.esri.com
> >     <http://sampleserver.esri.com> or whatever it is -- make
> >      > this type of development much simpler.
> >      > However, to accomplish this goal, there still needs to be a
> >     champion of
> >      > the task -- someone who is reasonably experienced in Javascript, and
> >      > willing to step up and take on the task of providing the OpenLayers
> >      > community with the support it needs to get this support into the
> >      > library. This means that, for example, documentation and examples
> >     would
> >      > need to be written, etc.  and the contributo would likely need to
> >      > demonstrate some willingness to continue to support developers in
> >      > maintaining the code, since none of us are, as far as i know,
> >      > particularly well-versed or highly motivated to maintain the code
> >     at a
> >      > reasonable level of quality on our own.
> >      > You proposed a number of possible solutions:
> >      >> * Turning on WMS in ArcServer and pointing TileCache at it.
> >     Works but
> >      >> ArcServer wants to serve the layers independently, so I get back to
> >      >> the SLD problem.
> >      > To me, this seems like a configuation issue. That is, the WMS serves
> >      > layers individually, but they're typically possible to combined, with
> >      > something like:
> >      > layers=0,1,2
> >      > In your TileCache config. However, I only know very little of ESRI's
> >      > software, so I can't comment on that for sure, and I haven't seen any
> >      > links that help me look at your setup to confirm-or-dis-confirm this
> >      > notion of mine.
> >      >> * Generating a tile cache out of ArcServer and kludging TileCache to
> >      >> serve it up.
> >      > I don't know what 'ArcServer' is, but I expect that this would have
> >      > essentially the same problem that has existed i ArcGIS caches in the
> >      > past, which is that most people who have access to caches don't know
> >      > what the parameters used to create the cache are.
> >      >> And lastly:
> >      >> * Pulling the AGS plugin for OpenLayers out of the sandbox
> >      > This code should probably be in trunk, as described above. The
> >     fact that
> >      > it is not is because no sufficiently motivated Javascript
> >     developer has
> >      > made it so. (As Mr. Schaub pointed out at one point, these things
> >     arent
> >      > meant to happen magically; in Open Source, you need to either pay
> >      > someone to do it, or do it yourself.)
> >      >> I haven't actually tried the last bit because of some of your emails
> >      >> I've found from 2007. It sounds like AGS is a dead-end. Is this
> >     true?
> >      >> Is there a specific reason?
> >      > AGS is not a dead-end, but you probably read emails where I was
> >      > expressing my frustration, centered mostly around the stuff above.
> >      > Specifically, the same problem as there is in many aspects of the
> >      > project has arisen here:
> >      >  * Someone writes some code
> >      >  * The code is insufficient, poorly documented, or simply 'not done'
> >      >  * The author of the code expects it to get in trunk
> >      >  * Requests to do more work to make it happen are ignored.
> >      > The general assumption in these cases seems to be that if someone
> >     writes
> >      > some code, it will automatically be in trunk, which is simply
> >      > unrealistic. OpenLayers is a high quality code library, and it seems
> >      > completely reasonable to me that in order to keep it that way, we
> >     have
> >      > to maintain some standards. However, this means that some code
> >     does not
> >      > make it into trunk in a timely manner, and the patch authors feel
> >      > shunned or ignored. Although this is almost always not the case, the
> >      > emotions there are very frustrating as a developer: the
> >     expectation that
> >      > patches lead to changes in the library 'for free' is just unfair
> >     to the
> >      > core development team.
> >      > In this case, I was unable to st up the ArcGIS cached layer code
> >     to talk
> >      > to any server I could find documented on the web. If I an't do it, I
> >      > can't imagine that most users can do it: I'm a pretty smart guy in
> >      > general. If I cant' pull it off, then it is probably the case that
> >      > others can't either, and that means that putting it in trunk is
> >     asking
> >      > for pain. With that in mind, I saw no significant personal benefit to
> >      > working on it, and the code has sat.
> >      > My expressed frustration is/was probably unfair. I'm not aware of any
> >      > problem with the code as it exists -- except that people are
> >     using it,
> >      > and not giving back to the community by trying to get it into
> >     trunk. I
> >      > find that combination extremely unfair, given the amount of work
> >     that so
> >      > many people put in to make the library possible. I'd love to see some
> >      > organizations out there who are using this code really invest in
> >     it, and
> >      > make the library better for everyone as a result. This could come
> >     in the
> >      > form of paying developers to work on it, project sponsorship with a
> >      > stated request -- though not binding, clearly somewhat motivating
> >     -- or
> >      > other potential venues. Without any of this kind of support,
> >      > organizations -- of which there are several -- using the AGS code are
> >      > simply taking from the library, and not giving back. that type of
> >      > behavior is frustrating to me, and that has probably come through in
> >      > previous emails.
> >      >> And input would be greatly appreciated.
> >      > Using ESRI services in OpenLayers needs champions -- people who are
> >      > willing to truly support the cause. ArcXML has a champion in the
> >     form of
> >      > dzwarg, who has been working with me on an ArcXML ticket. ArcGIS rest
> >      > layer had a champion in the form of Jeff Adams. AGS cache needs the
> >      > same. The community could probably rally up and make this support
> >      > happen: lots of people have expressed interest. Open Source isnt all
> >      > about things being done for you, and I'd love to see some of the
> >     users
> >      > of the software really invest in OpenLayers more than they have up to
> >      > this point. ESRI-specific services are a great example of this, where
> >      > there's a lot of code floating about, but relatively limited
> >     support of
> >      > it outside of the companies using it or specific use cases, and
> >     that's
> >      > a great example of what I'd love to see change.
> >      > Sorry for using you email as a jumping off point for a 'rant'
> >     like this,
> >      > but the state of ESRI-in-OpenLayers is an excellent example of what
> >      > *feels* like poor community support of library in favor of immediate
> >      > needs, and I really like the idea of that changing. (And if I'm
> >      > completely ignoring a significant effort in this regard, this is a
> >      > perfect oppourtunity for the existing community members whose work I
> >      > have been ignoring to step up and tell me how wrong I am!)
> >      > Regards,
> >      > Christopher Schmidt
> >      > MetaCarta
> >      > _______________________________________________
> >      > Dev mailing list
> >      > Dev at openlayers.org <mailto:Dev at openlayers.org>
> >      > http://openlayers.org/mailman/listinfo/dev
> >     Regards, Carl SHE
> >     View this message in context:
> >     http://n2.nabble.com/ESRI-and-OpenLayers-tp2412861p2444558.html
> >     Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> >     Dev mailing list
> > Dev mailing list
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
