[OpenLayers-Dev] WMS Overlay Disappears
Andrew Ayre andy at britishideas.com
Tue Mar 31 01:17:13 EDT 2009
I needed to add the maxResolution parameter to get it working. I also
switched from Mapnik to Osmarender but I'm not sure if that is a factor.
Andy
Andrew Ayre wrote:
> Hi! I am generating a map using OpenLayers with an OSM base map and a
> WMS overlay. At the backend I am running GeoServer 1.7.3 with PostGIS.
> I can view my WMS data fine in the client in GeoServer and in uDig.
> However when I overlay it on my OpenLayers map it disappears at nearly
> all the zoom levels. Here is a demo:
>   http://www.britishideas.com/osm
> When you load this you can see a black dot over southern Arizona. This
> is my overlay. When you zoom in it disappears.
> Any ideas what I am doing wrong?
> thanks, Andy
Andy
PGP Key ID: 0xDC1B5864
More information about the Dev mailing list
