[OpenLayers-Dev] text labels in IE8
Julien-Samuel Lacroix jlacroix at mapgears.com
Mon May 4 10:19:01 EDT 2009
It would help to know where the files are coming from.
Is the compressed file on openlayers.org [1] built from SVN or from a
release?
Do you use trunk or a sandbox?
Julien
[1] http://openlayers.org/dev/OpenLayers.js
Mike Adair wrote:
> So I've been banging my head on IE for long enough on this, I'd like to
> know if anyone else has any ideas...
> I'm trying to get the new vector labeling working in IE8 and to figure
> out why it's not working locally.  All test cases are in IE8
> compatibility mode, Quirks mode.
> If I go to the examples page at:
> http://openlayers.org/dev/examples/vector-features-with-text.html  it
> works without a problem, labels show up aligned with the vector features.
> If I load the example served from my local machine (from an MS4W
> instance), the labels all appear in the top-left corner. (both default
> single-file build and loading individual files)
> If I load the example served from my local machine  but with the
> OpenLayers single file build at http://openlayers.org/dev/OpenLayers.js
> it works properly.
> Doing a diff on the generated VML shows that for the one that works, the
> <ovl:textbox> node has extra style properties of:
> "MARGIN-TOP: 88.875pt; MARGIN-LEFT: 141.375pt; TOP: auto; LEFT: auto"
> which appears to make the labels show up in the correct place.  I've
> searched the WML renderer code and I can't find anywhere that is adding
> those properties
> So I guess the questions are:
> - what's the difference between a local single file build and the one
> server from openlayer.org?
> - anyone know what is adding those extra style properties?
> Thanks for any pointers,
> Mike
Mapgears
http://www.mapgears.com/
More information about the Dev mailing list
