[OpenLayers-Dev] [Fwd: [OpenLayers-Trac] [OpenLayers] #2344: label offset not working as documented]
Christopher Schmidt crschmidt at metacarta.com
Sun Nov 8 12:48:50 EST 2009
On Sun, Nov 08, 2009 at 05:44:20PM +0100, Andreas Hocevar wrote:
> Hi,
> very good catch Roald. I think you are absolutely right.
> +1 for splitting examples into a release and a trunk version.
Released:
 http://dev.openlayers.org/releases/OpenLayers-2.8/examples/lite.html
 http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers-js.html
Trunk:
 http://openlayers.org/dev/examples/lite.html
 http://dev.openlayers.org/apidocs/files/OpenLayers-js.html
-- Chris
> Regards,
> Andreas.
> Roald de Wit wrote:
> > Hi list,
> > The ticket below made me wonder what david was referring to. The API
> > documentation on the site points (correctly) to our 2.8 release and not
> > trunk, so that (most probably) could not be it. I think he referred to
> > the examples, which use trunk.
> > Would it make sense having the examples link on the home page point to
> > the latest stable release as well? This could avoid some confusion.
> > Regards, Roald
> > -------- Original Message --------
> > Subject: 	[OpenLayers-Trac] [OpenLayers] #2344: label offset not working
> > as documented
> > Date: 	Sun, 8 Nov 2009 08:59:41 +1030
> > From: 	OpenLayers <trac-20090302 at openlayers.org>
> > Reply-To: 	dev at openlayers.org <dev at openlayers.org>
> > CC: 	trac at openlayers.org <trac at openlayers.org>
> >  Reporter:  david    |       Owner:
> >      Type:  feature  |      Status:  new
> >  Priority:  minor    |   Milestone:  2.9 Release
> > Component:  general  |     Version:  2.8
> >  Keywords:           |       State:
> >  Offset doesn't work on the current release. Downloaded latest SVN and it
> >  works. Suggest that documentation should not advance faster than the
> >  software.
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
