[OpenLayers-Dev] general questions regarding the process of patches for new/enhanced functionality
Marc Jansen jansen at terrestris.de
Sat Oct 3 07:16:45 EDT 2009
Hi Bart,
thanks for the warm welcome :-)
Bart van den Eijnden (OSGIS) schrieb:
> Hi Marc,
> welcome to the community, you're almost there (opening a ticket with a
> patch is the right way), a few pointers:
> -it is wise to set the state of your ticket to review, also if you
> want it to get attention, make sure the milestone is the next possible
> release (right now 2.9)
OK. I'll change that
> -a patch with a testcase is better than a patch without a testcase, so
> if you could look into how to write a testcase that would be great
OK. I will try to do that as well.
> -a patch should ideally work against trunk
Both patches work against the latest version of the trunk... or am I
misinterpreing something,
Regards,
Marc
> Best regards,
> Bart
> Marc Jansen wrote:
>> Hi devs,
>> I recently opened two tickets ([1], [2]) for new / enhanced
>> functionality of OpenLayers components. Both of them have (more or
>> less trivial) patches attached to provide the actual functionality.
>> I would love to have a short note/review about the code in question
>> by someone with deeper insights in the project.
>> I am not quite sure if I did everything the "OpenLayers-Way". Is the
>> process of opening a ticket and submitting a patch the desired way?
>> Should I have started a discussion on this list prior to opening the
>> ticket? Please help me since I would love to participate in the project.
>> BTW: I have not handed in a CLA up until now. Maybe we can fix this
>> in Sydney, as I guess many from the project will meet up there.
>> Regards,
>> Marc
>> [1] http://trac.openlayers.org/ticket/2266
>> [2] http://trac.openlayers.org/ticket/2288
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
