[OpenLayers-Dev] general questions regarding the process of patches for new/enhanced functionality
Marc Jansen jansen at terrestris.de
Wed Oct 7 02:17:22 EDT 2009
Hi Tim,
thanks for the review. Renaming seems reasonable, I guess there is no
wrong or right.
As for the default: I chose not to break the behaviour of the control
when being called without the parameter "eliminateDuplicates" set. On
the other hand: I can hardly guess of any situation where you wanted
duplicate atttribution texts.
Just my two cents,
Regards,
Marc
Tim Schaub schrieb:
> Thanks for the excellent contribution Marc.
> http://trac.openlayers.org/changeset/9720
> I think it would be worth making eliminateDuplicates true by default
> (and maybe changing it to simply "duplicates" and making it false).
> Would anyone object?
> Tim
> Marc Jansen wrote:
>> Hi Bart,
>> thanks for the warm welcome :-)
>> Bart van den Eijnden (OSGIS) schrieb:
>>> Hi Marc,
>>> welcome to the community, you're almost there (opening a ticket with a
>>> patch is the right way), a few pointers:
>>> -it is wise to set the state of your ticket to review, also if you
>>> want it to get attention, make sure the milestone is the next possible
>>> release (right now 2.9)
>> OK. I'll change that
>>> -a patch with a testcase is better than a patch without a testcase, so
>>> if you could look into how to write a testcase that would be great
>> OK. I will try to do that as well.
>>> -a patch should ideally work against trunk
>> Both patches work against the latest version of the trunk... or am I
>> misinterpreing something,
>> Regards,
>> Marc
>>> Best regards,
>>> Bart
>>> Marc Jansen wrote:
>>>> Hi devs,
>>>> I recently opened two tickets ([1], [2]) for new / enhanced
>>>> functionality of OpenLayers components. Both of them have (more or
>>>> less trivial) patches attached to provide the actual functionality.
>>>> I would love to have a short note/review about the code in question
>>>> by someone with deeper insights in the project.
>>>> I am not quite sure if I did everything the "OpenLayers-Way". Is the
>>>> process of opening a ticket and submitting a patch the desired way?
>>>> Should I have started a discussion on this list prior to opening the
>>>> ticket? Please help me since I would love to participate in the project.
>>>> BTW: I have not handed in a CLA up until now. Maybe we can fix this
>>>> in Sydney, as I guess many from the project will meet up there.
>>>> Regards,
>>>> Marc
>>>> [1] http://trac.openlayers.org/ticket/2266
>>>> [2] http://trac.openlayers.org/ticket/2288
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>> Dev mailing list
More information about the Dev mailing list
