[OpenLayers-Dev] Creating own baselayer
Julien-Samuel Lacroix jlacroix at mapgears.com
Wed Sep 9 09:39:01 EDT 2009
I think you will need a server-side application to build a your tiles
from the tiff+mid/mif data. If you already have your tiles, you could
arrange them in a way that looks like the end result of TileCache [1].
Otherwise, I suggest you to use MapServer [2] or GeoServer [3] to build
your maps.
Note that if you can't run MapServer/GeoServer on your production server
and the number of tiles you generate is fairly small, you could build
the cache on your development machine and upload them to the server.
[1] http://tilecache.org/
[2] http://www.mapserver.org/
[3] http://geoserver.org/display/GEOS/Welcome
Julien
fitz5487 wrote:
> Hi,
> I have created an openlayers application using google maps as the baselayer,
> however, the organisation I am working for require me to use ordinance
> survey maps which are currently in .tiff format, along with the accompanying
> mid/mif files. There are tiles for 3 different zoom layers. Is there anyway
> of using these tiles directly in openlayers, or is this going to be a much
> more complicated proceedure. I have seen that I may need to use a WMS but my
> facilities are very limited, and I woundnt have though I will be able to use
> java or python in this project.
> Does anyone have an idea, or any relevant literature they can point me
> towards? I would be much obliged.
> Kind regards,
> Lee
Mapgears
http://www.mapgears.com/
More information about the Dev mailing list
