[OpenLayers-Dev] Buffer/radius in GetFeatureInfo request
Björn Harrtell bjorn.harrtell at gmail.com
Tue Sep 15 16:06:07 EDT 2009
Another option would be to use a WFS query with a BBOX filter. WMS
GetFeatureInfo has other drawbacks than the buffer thing, like that
the result isn't guaranteed to look in any standard way so it might
vary with data source and software versions and must be manually
parsed, compared to WFS where OpenLayers can do both the querying and
result parsing.
/Björn
2009/9/15 Andreas Hocevar <ahocevar at opengeo.org>:
> Hi Niklas,
> Ringdahl Niklas wrote:
>> I don't know if it's possible to update right now, but this improvement may be the best argument for that. Will it work with external graphics as well? If not, is it possible to set a size in the SLD to mimick this behaviour?
> I have not tried if that works. If it does not, you can still set the
> BUFFER vendorParam. For more details, see
> http://jira.codehaus.org/browse/GEOS-1434 or ask on the geoserver-users
> list.
> Also, i see that this is available since version 1.7.4, not 1.7.6.
> Regards,
> Andreas.
>> Regards,
>> - Niklas
>> -----Ursprungligt meddelande-----
>> Från: Andreas Hocevar [mailto:ahocevar at opengeo.org]
>> Skickat: den 15 september 2009 16:35
>> Till: Ringdahl Niklas
>> Kopia: dev at openlayers.org
>> Ämne: Re: [OpenLayers-Dev] Buffer/radius in GetFeatureInfo request
>> Hi,
>> If it is possible for you to upgrade to GeoServer 1.7.6, you will get intelligent point radius selection for free, without the need to provide an extra vendorParam. The way it works is that it analyzes the SLD that created the symbol, and will return all the features that are *visible on the map* at the spot that you clicked.
>> Regards,
>> Andreas.
>>> Hi list.
>>> I'm using the WMSGetFeatureInfo control to query a point layer, and
>>> would like to increase the area where a point gets hit. Somewhere I
>>> read about a vendorParam "buffer" or "radius" for Geoserver that would
>>> do the trick, but I can't seem to get it to work. Does anyone have any
>>> hints or code?
>>> I'm using OpenLayers 2.8, Geoserver 1.7.3 and PostGreSQL 8.3.5
>>> Thanks in advance!
>>> - Niklas
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
> Andreas Hocevar
> Dev mailing list
More information about the Dev mailing list
