[OpenLayers-Dev] cropped icons
Andreas Hocevar ahocevar at opengeo.org
Thu Sep 17 11:48:19 EDT 2009
Hi Ibrahim,
you should not use gutter with tilecache. Instead, configure tilecache
to use metatiles.
Regards,
Andreas.
ibrahim saricicek wrote:
> Hi all,
> I'm using mapserver, tilecache, openlayers..
> My symbols or the labels on the tile edges are cropped,
> When i use on mapserver
> "PARTIALS FALSE", the sybols on the edges are being dismissed. But i
> want to show them all.
> Then i used gutter on OpenLayers; but it doesn't work too..
> new OpenLayers.Layer.WMS("MY Map",
>                     "http://127.0.0.1:8080/cgi-bin/tilecache.cgi?",
> {layers: 'MY_Map', format: 'image/png' , *gutter:50*},
> You can see the problem on atteched screenshot..
> What should i do to prevent those?
> Thanks for any help in advance..
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
