[OpenLayers-Dev] Chrome issue with WMS
Cédric Moullet cedric.moullet at camptocamp.com
Thu Apr 1 05:49:28 EDT 2010
It seems that this use case is not always reproducible.
OS: Windows Vista
Chrome Version: 4.1.249.1045 (42898)
Here is more detailes use case.
1. http://www.openaddresses.org/
 <http://www.openaddresses.org/>2. Search Lausanne in geonames search and
recenter to Lausanne
3. With Shift key, draw a small zoom rectangle in the middle of the red
points.
4. You should see the big points now.
At least by me, I can reproduce the issue.
Can you reproduce this case ? If yes, any idea of the cause ?
Thanks a lot,
Cédric
2010/4/1 Cédric Moullet <cedric.moullet at camptocamp.com>
> Hi,
> In OpenAddresses, we have the following problem with chrome:
> 1. Try to open with chrome
> http://www.openaddresses.org/?northing=5863427.1119846&easting=738362.58397773&zoom=12&overlayOpacity=0.7
> <http://www.openaddresses.org/?northing=5863427.1119846&easting=738362.58397773&zoom=12&overlayOpacity=0.7>2.
> Make a zoom in
> Result: we see large red points. It seems that the WMS layer is not refresh
> and keep the resized image.
> If needed the code of the layer creation is here:
> http://code.google.com/p/openaddresses/source/browse/trunk/openaddresses/openaddresses/public/app/js/OpenAddressesLayout.js#257
> This affects only chrome: do you have an idea of the cause of the problem ?
> Thanks in advance,
> Cédric
> Geospatial Director Camptocamp SA
> Cédric Moullet
> PSE A
> CH-1015 Lausanne
> www.camptocamp.com  / www.mapfish.org / twitter.com/cedricmoullet /
> mapfishblog.blogspot.com/
> +41 79 759 69 83 (mobile)
> +41 21 619 10 21 (direct)
> +41 21 619 10 10 (centrale)
> +41 21 619 10 00 (fax)
Cédric Moullet
PSE A
CH-1015 Lausanne
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100401/15201277/attachment.html
More information about the Dev mailing list
