[OpenLayers-Dev] Problems trying to move a Feature (Marker)
Cúmar Cueva qmarqeva at gmail.com
Thu Apr 1 18:43:17 EDT 2010
Hi guys,
Please I need your help. I want to move a Marker (that was colocate using a
VectorLayer, that works ok), but I can't do that, yet... Here is the code:
For create the Map:
//Map
map = new OpenLayers.Map("map", {
                controls:[
                    new OpenLayers.Control.Navigation(),
new OpenLayers.Control.MousePosition(),
                    new OpenLayers.Control.Attribution(),
                    new OpenLayers.Control.Permalink(),
                    new OpenLayers.Control.PanZoomBar(),
new OpenLayers.Control.KeyboardDefaults(),
new OpenLayers.Control.LayerSwitcher()
                maxExtent: new
OpenLayers.Bounds(-79.23381,-3.96749,-79.17630,-4.00457),
                displayProjection: new OpenLayers.Projection("EPSG:4326"),
projection: new OpenLayers.Projection("EPSG:900913"),
                units: 'm',
                numZoomLevels: 19,
                maxResolution: 'auto'
 map.addLayer(new OpenLayers.Layer.OSM.Mapnik("Mapnik"));
And a function for move:
  function moveFeatures(vectorLayer1){
var features = vectorLayer1.features, selectedPlane = null;
   for (var i=features.length-1;i>=0;i--) {
   var feature = features[i];
   var poppedup = feature.attributes.poppedup;
   var x = feature.geometry.x + Math.cos(15 * Math.PI / 180) / 5;
   var y = feature.geometry.y + Math.sin(15 * Math.PI / 180) / 5;
if (poppedup == true) {
   selectControl.unselect(feature);
   if (vectorLayer.map.getExtent().contains(x, y)) {
var newPoint = new OpenLayers.LonLat(x, y);
feature.move(newPoint);
   selectControl.select(feature);
   else {
   vectorLayer.destroyFeatures([feature]);
feature.destroy();
feature = null;
//only for simulate moved
   setTimeout(function(){moveFeatures(vectorLayer, vectorLayer.features ||
[])}, 1000);
I put some "alerts" in javascript for view lat and lon values, and  these
change correctly... but the Marker in the map don't move !!!! please help
me....
Atte,
Cúmar Cueva
More information about the Dev mailing list
