[OpenLayers-Dev] OpenLayers 2.9 Release Candidate 2
bartvde at osgis.nl bartvde at osgis.nl
Fri Apr 9 07:30:20 EDT 2010
The OpenLayers Development Team is proud to announce the second release
candidate of OpenLayers 2.9!
RC2 closes an additional small number of bugs in the 2.9 RC1 Release:
* Superfluous "limit" in Layer.XYZ (#2558)
* accept center with no layers in map constructor (#2561)
* setOpacity not working on Google layer (#2562)
* labelAlign with one character does not work in IE (#2563)
* API docs of Map constructor are not in line with the actual code (#2564)
* don't use dot notation for 'abstract' (#2569)
We invite you to help us test the second 2.9 release candidate! To test
2.9 RC2 in your applications, include the following tag in your
OpenLayers-powered page:
<script src="http://openlayers.org/api/2.9-rc2/OpenLayers.js"></script>
As always, the source is available at http://openlayers.org/download/. Bug
reports can be filed in Trac, under the 2.9RC2 version and 2.9 milestone.
For information on possible changes that will need to be made between this
version of OpenLayers and previous versions, please look at the Release
notes, available at the Release Notes information[1].
We look forward to your feedback on this release.
[1] http://trac.openlayers.org/wiki/Releas/2.9/Notes#CompatibilityNotes
More information about the Dev mailing list
