[OpenLayers-Dev] [GeoExt] Issue with css
Mulone mulone at rome.com
Fri Apr 9 09:18:00 EDT 2010
Hi guys,
I'm running a popup on GeoExt with this code:
    var popup = new GeoExt.Popup({
    	title: 'GetFeatureInfo',
    	lonlat: location,
        width: 400,
        html: text,
        maximizable: true,
        collapsible: true,
        map: this.olMap
    popup.show();
I followed this example:
http://dev.geoext.org/trunk/geoext/examples/popup.html
This works fine, but the style of the map is broken, as you can see here:
http://img136.imageshack.us/img136/1005/brokencss.png
I checked the relevant styles and they seem to be imported properly.
How can I debug this and make sure that the right styles are defined?
Besides, is there a forum/ML for GeoExt?
Cheers
Mulone
Mulone
PhD student
View this message in context: http://n2.nabble.com/GeoExt-Issue-with-css-tp4877000p4877000.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
