[OpenLayers-Dev] GetFeature control doesn't select from WFS with multiple feature types.
Attila BERÉNYI atis at airdesignstudio.hu
Sat Apr 10 14:21:17 EDT 2010
Dear Marc,
Thank you very much, finally I was able to solve the problem.
I was testing with the 'old' version of OpenLayers (2.8), after patching
it worked like a charm, 2.9 RC1 already contains a patch.
Anyway thanks again!
Attila
2010.04.09. 20:18 keltezéssel, Marc Pfister írta:
> Attila BERÉNYI [mailto:atis at airdesignstudio.hu] wrote:
>> I am facing the same problem, do you figured out any solution already?
> I found the solution to selecting multiple feature types from WFS GetFeature in this mailing list posting:
> http://www.mail-archive.com/dev@openlayers.org/msg03106.html
> I also added some logic that selects the lowest dimension geometry - generally if a user is clicking on a point within a polygon, they are intending to pick the point, not the polygon. A user who wants to select the polygon will generally not click on top of the point.
> Marc
More information about the Dev mailing list
