[OpenLayers-Dev] releasing 2.9
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Fri Apr 23 08:40:24 EDT 2010
*shrug*
If so, it must have been manual, and since it was never added to our release process, I don't know how it was done. (This is a side effect of losing Erik as our 'Write it down!' taskmaster.)
It seems like we have a number of small fixes which might be appropriate for a 2.10, so if so, we should just add this to our release process steps for that release. I don't have a good suggestion on how to do this, other than manual editing.
-- Chris
On Apr 23, 2010, at 1:56 AM, ext Bart van den Eijnden wrote:
> Hey Chris,
> see:
> http://trac.openlayers.org/ticket/2589
> apparently 2.8 did have something in there?
> Check out:
> http://openlayers.org/api/2.8/OpenLayers.js
> OpenLayers.VERSION_NUMBER="OpenLayers 2.8 -- $Revision: 9492 $"
> Best regards,
> Bart
> On Apr 22, 2010, at 6:10 PM, Bart van den Eijnden wrote:
>> Thanks Chris, the only thing missing is the 2.9 release in the VERSION_NUMBER property, how is that done?
>> Best regards,
>> Bart
>> On Apr 22, 2010, at 5:49 PM, <christopher.schmidt at nokia.com> wrote:
>>> On Apr 22, 2010, at 11:45 AM, ext Bart van den Eijnden wrote:
>>>> Hi Chris,
>>>> I've done all the steps up until point 9 in the release procedure [1], are you able to do steps 10 to 14? I've already created the 2.9 Trac version and made it the default, I'll pick up at 16 when I hear back from you.
>>> Done!
>>> -- Chris
More information about the Dev mailing list
