[OpenLayers-Dev] SLD Select Control Bug
Bart van den Eijnden bartvde at osgis.nl
Sat Apr 24 14:36:53 EDT 2010
Btw, this is still sandbox code and no OpenLayers code as yet.
Right, but in my opinion (I wrote the code), this is a problem of Geoserver.
With Mapserver the generated SLD works fine.
I've raised the issue with the Geoserver people, but got no answer:
http://permalink.gmane.org/gmane.comp.gis.geoserver.user/20646
Best regards,
Bart
On Apr 24, 2010, at 7:17 PM, Debasish Sahu wrote:
> There seems to be bug with the SLD Select control .See the attached image.
> If I select the SLD Select with point option and Cities as the selection layer , the control selects all of the Cities features where as it should have selected just
> the one that I have circled in blue since that was the feature that I had clicked.
> Thanks and Warm Regards
> Debasish Sahu
> <select.gif>_______________________________________________
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
