[OpenLayers-Dev] setting singleTile=true breaks layer ?
strk strk at keybit.net
Thu Apr 29 11:22:04 EDT 2010
Hi all,
I've been trying to have a control switch a layer between
'tiled' and 'singleTile' but hit what looks like a bug.
See the test:
 http://strk.keybit.net/tmp/ol/st.html
The test starts in multi-tiled, clicking on the first bottom-line
control does an addOptions({singleTile:true}). After that if you
zoom in you'll see a _single_ tile being loaded but then placed
as if it was one of a multi-tile set !
This is using http://openlayers.org/api/OpenLayers.js.
Is it a bug ?
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
More information about the Dev mailing list
