[OpenLayers-Dev] Draw boxes on the image pressing shift key
Moiz Bhukhiya moiz.bhukhiya at gmail.com
Wed Aug 4 18:22:08 EDT 2010
Thanks alot Tim for your response.
It seems like it will be helpful for resizing the square box, but how to
move this square and the square box seems to be in 45 degree angle to the
horizontal line. I need square to be drawn inline with horizontal line. It
should be resizable by dragging it edges like we see in the Jquery plugin I
mentioned. http://odyniec.net/projects/imgareaselect
Thanks again for your help. I really appreciate it.
Moiz
On Wed, Aug 4, 2010 at 2:49 PM, Tim Schaub <tschaub at opengeo.org> wrote:
> On 8/4/10 12:31 PM, Moiz Bhukhiya wrote:
> > Hello Devs,
> > I am using Openlayers to display images from Djatoka Image server. I am
> > using two different layers.
> > 1. To draw boxes on an image which is OpenLayers.Layer.Boxes
> > 2. To dynamically draw boxes on images I am using OpenLayers.Control()
> > Using Control() functionality I can draw boxes on the image pressing
> > shift key and on mouse down, and on mouse up I can get the coordinates
> > of the box on the image. On mouse up the box disappears and I get the
> > coordinates. My problem is I do not want this box to disappear until I
> > invoke it. I want to draw the box and resize it if required (like we do
> > in Jquery crop plugin Eg:http://odyniec.net/projects/imgareaselect )
> > It would be of great help if you could guide me how do I achieve this
> > functionality.
> Alternatively, you could use a Vector layer and a DrawFeature control
> with a RegularPolygon handler.
> See http://openlayers.org/dev/examples/regular-polygons.html
> Sounds like an irregular polygon with four sides (rectangle) snapped to
> 90 would give you want you want.
> Tim
> > Thanks,
> > Moiz
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100804/a50359ca/attachment.html
More information about the Dev mailing list
