[OpenLayers-Dev] maintenance releases
Bart van den Eijnden bartvde at osgis.nl
Tue Feb 23 12:25:41 EST 2010
Picking up on an old thread, IIRC we had quite a bit of consensus on this.
So what do we do for 2.9, a quick maintenance release or a normal full-blown release?
Best regards,
Bart
On Sep 15, 2009, at 9:00 PM, Tim Schaub wrote:
> Hey-
> We periodically discuss releasing on a fixed schedule.  Though a few
> releases have come close to sticking to a schedule, my impression is
> that it has been a tough to pull off.  It is also my impression that the
> release process feels onerous enough to enough people that we are
> collectively avoiding it.
> I'm interested in discussing doing more "maintenance" releases between
> minor releases.  What exactly would change about the release process [1]
> I'm not sure, but the goal would be to make it less work overall.
> While this might seem extreme, I'm curious what people would think about
> kicking out maintenance releases *without* going through the release
> candidate cycle.  Taking this further, a maintenance release manager
> could decide to stick to a schedule and release even if there were known
> regressions.
> While the result may be something of questionable value, I do think it
> would bring some benefits.  My impression is that there are a lot of
> people running applications off the trunk currently.  I also imagine a
> fair number are running "sandbox" functionality or their own patched
> versions.  Having more frequent releases would not be that much
> different than pegging applications to a specific version of the trunk.
>  I think all would agree this is safer than having an application run
> off the head revision.
> This would also have the benefit for contributors of more quickly seeing
> their contribution in an official release - potentially encouraging more
> contributions.
> Obviously there would be details to work out about the process, but I
> would suggest a pared down version of the major/minor release process -
> with leeway for the maintenance release manager to decide on some
> specifics (e.g. if all tests pass on this date, bump tickets, release,
> and make notes about known issues).
> Thoughts?
> Tim
> [1] http://trac.openlayers.org/wiki/Release/Procedure
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
