[OpenLayers-Dev] github attempts
christopher.schmidt at nokia.com
Mon Jul 5 00:38:52 EDT 2010
On Jul 4, 2010, at 6:45 PM, ext Tim Schaub wrote:
> On 7/4/10 8:33 AM, christopher.schmidt at nokia.com wrote:
>> On Jul 4, 2010, at 10:28 AM, ext christopher.schmidt at nokia.com wrote:
>>> Yo,
>>> So, in testing github out, I:
>>> 1. Forked openlayers/openlayers. (I did this a week ago)
>>> 1a. Since my fork was out of date, I did:
>>> git pull git at github.com:openlayers/openlayers.git master
>>> git push
>>> To update my fork.
>>> 2. Made some changes in my fork, and pushed them
>> Though I now see that fredj had already made the same changes. Curses!
>> fredj, I think you need to be pushing to the master repo more often :)
>> I assume you have access; is there a reason to be way out on a branch
>> like you are?
> As far as I can tell, fredj has been using the online fork queue tool to
> cherry pick commits from his fork, replaying these on the central repo.
The WMS Untiled commits --
http://github.com/fredj/openlayers/commit/66904e7346fe76f7b13ccf3763ad84ad73d3082b
appear to not be in the main openlayers/openlayer repo, unless
I'm missing something. Does that seem accurate? (This is the change
that I'm pretty sure I duplicated.)
> The result is that we have identical commits in the central repo and
> fredj's repo, but they don't have the same SHA. I think the same was
> happening between cedric's fork and fredj's. This is not that big a
> deal, except that it makes the forks look artificially divergent - and
> the central repository's history will look weird when we get things
> properly merged. Not that big a deal, things will get smoother as we
> all get handier with git.
> Chris, I think what you did looks good. A couple things that you might
> want to consider (depending on what makes sense to you).
> git remote add central git at github.com:openlayers/openlayers.git
> If you run this in your repo, you can start using "central" to refer to
> the central repo. Then pulling recent changes from the central repo
> would look like this:
> git pull central master
Nothing really special here except that central is a fancy name for
git at github.com:openlayers/openlayers.git, right?
> This pull implicitly does a fetch and merge. If you're pulling from a
> somewhat untrustworthy remote, it probably makes sense to `git fetch`
> and `git merge` independently.
Gotcha. I mostly just 'pull' and hope git does magic :) Maybe someday
this will bite me; for now, it seems to be doing the right things.
> After you do this, you can poke around your .git directory to see how
> things are configured (see .git/config for your named remote repositories).
> cat .git/refs/remotes/central/master
> That's the SHA of the latest commit you have from the master branch in
> the central repo.
> git show central/master
> That's git's view of the latest commit you have from the master branch
> in the central repo. (And `git log central/master` for the full log.)
Ah, so other tools get more if you actually set up a remote. Gotcha.
I'll keep that in mind.
-- Chris
> Tim
>> -- Chris
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
Regards,
Christopher Schmidt
Nokia
More information about the Dev
