[OpenLayers-Dev] Modifiy-Feature and Projection
Matt Priour mpriour at kestrelcomputer.com
Wed Jul 7 18:08:41 EDT 2010
It sounds like you need to explicitly set the srsName in the WFST format
options.
Matt Priour
Kestrel Computer Consulting
Dipl. Inf. Carsten Eider wrote:
>   Hi list,
> i am focussing a heavy bug being a hard showstopper in my project.
> Problem:
> We have developed a so called GeoEditor. It works fine if we stay in
> EPSG:31467.
> Now we switched to EPSG:900913 in order to be able to use GoogleMaps
> EPSG:900913 is our internalProjection, whereas data is saved in the
> backend as EPSG:31467.
> There are nearly no problems while joining, splitting and creating
> multipolygons.
> The trouble starts, whenever we modify a feature using a
> ModifyFeatureControl.
> After removing or moving a point data is send to the server in
> EPSG:31467 declared as EPSG:900913.
> Data is send via WFS-T to our GeoServer-Backend.
> Any suggestions where my problems come from?
> TIA
> Carsten
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Modifiy-Feature-and-Projection-tp5264819p5267556.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
