[OpenLayers-Dev] Generating a valid WFS object
Tim Schaub tschaub at opengeo.org
Fri Jul 9 17:39:52 EDT 2010
Hey-
A few things:
The featureType property is the local feature type name.  In your case,
I'm guessing this would be "poi" (not "tiger:poi").
The featureNS corresponds to the workspace URL in GeoServer.  If you
have a workspace named "tiger" with the "http://postgis.org" URL, then
use that URL.  I don't think the workspace form should allow you to
enter "http://postgis.org <http://postgis.org/>", but I could be wrong
about that.
You can only make requests for features on the same origin that is
serving up your application (see "same origin policy").  If this page is
served up from some place like http://ubuntu:8080/mymap.html then your
layer will work with the url you provided for your WFS.  If not, then
you need to proxy GeoServer on the same origin that serves up your
application (see "proxy geoserver on port 80" for details).
Alternatively, you can set up a proxy next to your application loader
and set OpenLayers.ProxyHost (see "openlayers faq").
If your WFS is on the same origin as your application, use a relative
URL so things will still work if you change domains.
Finally, if your map is not in EPSG:32632, then you'll likely want to
request features in your map projection.  OpenLayers can transform
coordinates client-side, but you'd need to provide the proj4js
definition for EPSG:32632 and your map projection.  If your OpenLayers
map is also in EPSG:32632, then you're set.
A guess at what might work for you (with some work):
     layer = new OpenLayers.Layer.Vector("WFS", {
         strategies: [new OpenLayers.Strategy.BBOX()],
         protocol: new OpenLayers.Protocol.WFS({
             url: "/geoserver/wfs",
             featureType: "poi",
             featureNS: "http://postgis.org",
             srsName: "EPSG:32632",
             version: "1.1.0"
Hope that helps,
Tim
On 7/9/10 2:50 PM, Ulrik Balslev wrote:
> Hi dev list,
> Using OpenLayers & Geoserver for WMS seems straight forward and works
> OK, but I cannot get it to work for WFS. I can't seem to create a valid
> OpenLayers layer object.
> A simple HTML page like this, gives a layer ('wfslayer'), that has no
> features (no data).
> Any hints? - Is it a security issue?
> regs.
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <title>WFS test!</title>
> <script src="./OpenLayers.js" type="text/javascript"></script>
> <script>
>          var wfslayer;
>         OpenLayers.ProxyHost = "proxy.cgi?url=";
>          function init() {
>      wfslayer = new OpenLayers.Layer.Vector("WFS", {
>                  url: "http://ubuntu:8080/geoserver/wfs",
>                  featureType: "tiger:poi",
>                  featureNS: "http://postgis.org <http://postgis.org/>",
>                  version: "1.1.0"
> </script>
> </head>
> <body onload="init()">
> </body>
> </html>
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
