[OpenLayers-Dev] WKT and GeometryCollection
strk strk at keybit.net
Thu Jul 15 06:55:03 EDT 2010
Hi guys,
this mail to try at getting somehow further
with Format.WKT support for GeometryCollection.
I've been spending some time 3 week ago on this
and produced some tickets and patches:
 [1] http://trac.openlayers.org/ticket/2705
 [2] http://trac.openlayers.org/ticket/2706
 [3] http://trac.openlayers.org/ticket/2707
WKT read, write and tests have problems.
write is broken, and ticket [3] provides
a patch for it.
testcase is also broken in that it fails to
test the current .read, duplicates write(array)
and lacks test for .write(geom). Again, ticket
[3] contains a patch for that.
Finally, 'read' is not really broken as it does
what's documented to do (return an array) but
would be nice to extend to also allow returning
a proper GeometryCollection.
I'm available to work on a patch for .read as well
but would like to see the other two patches acted
upon first, considering also that another, older,
ticket exists approaching the GC/WKT issue:
 [4] http://trac.openlayers.org/ticket/2240
Note that the patch in [4] also modifies .read
breaking backward compatibility, which I've been
warned to avoid.
So, are there chances to see the .write and testcase
patches reviewed/committed ? Should I go on with .read
reguardless of patch in [4] ?
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
More information about the Dev mailing list
