[OpenLayers-Dev] WMS 1.3.0 issue
Bart van den Eijnden bartvde at osgis.nl
Thu Jul 15 10:53:13 EDT 2010
but parseFloat("1.3.0") yield 1.3, so what is the problem?
Best regards,
Bart
On Jul 15, 2010, at 4:32 PM, Xurxo Mendez wrote:
> Hi all,
> In OL 2.9.1, I was trying to add a WMS layer to my map, setting its 'VERSION' parameter (in contructor) to '1.3.0', and I have a problem. The parameter must be a string, but in some pieces of code, at least in lib/OpenLayers/Layer/WMS.js, for example here (line 254):
> if (parseFloat(this.params.VERSION) >= 1.3) {
> it's parsed to a float, so it can NOT be '1.3.0' but '1.3'; but my server (a TDS one) doesn't recognize it as a valid version (it does support 1.3.0). By now I'm solving it like Godiva2 people do (http://behemoth.nerc-essc.ac.uk/ncWMS/godiva2.html), by adding two classes, WMS1_1_1.js(http://behemoth.nerc-essc.ac.uk/ncWMS/js/WMS1_1_1.js) and WMS1_3.js (http://behemoth.nerc-essc.ac.uk/ncWMS/js/WMS1_3.js), and initializing my layer as a WMS1.3 instance. Another way could be to avoid those kind of float-based checkings. Am I missing something important (I'm still starting with OpenLayers) or it's the way it must be used? Thank you in advance,
> Best regards,
> Xurxo Méndez Pérez
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100715/97a1fcf3/attachment.html
More information about the Dev mailing list
