[OpenLayers-Dev] Issue with Layer.clone()
    Tim Schaub
    tschaub at opengeo.org
    Fri Jul 23 01:49:55 EDT 2010
On 7/22/10 8:59 PM, Adam Ratcliffe wrote:
> Hi,
> I'm having an issue with the OpenLayers.Layer.clone() method.
> If the layer being cloned is a Vector layer, the source layer's
> Protocol object will be copied by reference to the clone object.  If
> the cloned layer's destroy() method is called the shared Protocol
> object will be destroyed and the source layer will cease to
> function.
> A possible solution would be to implement a clone() method on both
> the Protocol and Strategy interfaces and use this method when cloning
> the layer e.g.
This is certainly an issue.  Please open a ticket.
Tim
> for(var property in source) { var value = source[property]; if(value
> !== undefined) { if(value.clone) { value = value.clone(); }
> destination[property] = value; } }
> Cheers Adam _______________________________________________ Dev
> mailing list Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
