[OpenLayers-Dev] reading WKT Format and GEOMETRYCOLLECTIONS
    Marc Jansen
    jansen at terrestris.de
    Thu Jul 29 03:01:39 EDT 2010
Hi all.
Correction: the other write()-ticket is
http://trac.openlayers.org/ticket/2240
Regards,
Marc
On 29.07.2010 08:58, Marc Jansen wrote:
> Hi Eric,
> thanks for the response. The only ticket I found would be
> http://trac.openlayers.org/ticket/2707, which does not include a patch.
> There are other tickets (http://trac.openlayers.org/ticket/2707 and
> http://trac.openlayers.org/ticket/2706) which address the
> write()-method, but AFAICT ignore the read()-method.
> If there is consensus about the suggestion in #2707 (add the
> possibillity to control the return type for GCs), I'd give it a shot.
> Regards,
> Marc
> On 29.07.2010 08:28, Eric Lemoine wrote:
>> On Monday, July 26, 2010, Marc Jansen<jansen at terrestris.de>   wrote:
>>> Hi List,
>>> When using the WKT Format and feeding it -- via read() -- a
>>> GEOMETRYCOLLECTION we return an array of single features having
>>> geometries that represent the parts of the GEOMETRYCOLLECTION . It is
>>> AFAIK not possible to return one feature with a geometry of type
>>> OpenLayers.Geometry.Collection.
>>> Shouldn't we make it configurable how to handle GEOMETRYCOLLECTIONs?
>> Hi Marc. I think there's an ticket with a patch for that issue. To
>> help move forward with this issue you could possibly test the patch
>> and report back in the ticket. Thanks,
>>> And BTW, shouldn't read and write be APIMethods (at least for Format.WKT
>>> they aren't)
>> Yes they should. I'll go ahead and change that.
    Karten im (Inter|Intra)net?
    OpenLayers - Webentwicklung mit dynamischen Karten und Geodaten
    von M. Jansen und T. Adams, OpenSourcePress, München.
    ISBN: 978-3-937514-92-5
    URL:  http://openlayers-buch.de
   Dipl.-Geogr. Marc Jansen
   - Anwendungsentwickler -
   terrestris GmbH&  Co. KG
   Irmintrudisstraße 17
   53111 Bonn
   Tel:    ++49 (0)228 / 96 28 99 -53
   Fax:    ++49 (0)228 / 96 28 99 -57
   Email:  jansen at terrestris.de
   Web:    http://www.terrestris.de
   Amtsgericht Bonn, HRA 6835
   Komplementärin:  terrestris Verwaltungsgesellschaft mbH
   vertreten durch: Hinrich Paulsen, Till Adams
More information about the Dev
