[OpenLayers-Dev] Working on IE Mobile ?
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Thu Mar 4 09:26:27 EST 2010
All,
As a possible solution, you might take a look at SkyFire as well,
although, it's a sort of hack, as it uses a Server side proxy for the
complicated stuff in the browser, it does work, there's no Mapping based
controls available that I know of, so some inventive work will need to
be done there, but I haven't seen it get stumped with anything
javascript (yet).
bobb
>>> Zac Spitzer <zac.spitzer at gmail.com> wrote:
i'd say your stuck, IE mobile is a poor cousin of desktop IE,
which ain't a great blood line to start with when it comes to
modern javascript applications.
good luck, I'd say opera is a good bet
2010/3/4 Ramón Boza <rboza at sitep.com>:
> Hello,
> I’m doing some development for Windows Mobile using OL and have found
that
> OL is not working correctly on IE Mobile 6.5, using VS 2005 atm.
> After some investigations I have found someone that desist from using
IE
> Mobile to use Opera, see link
http://n2.nabble.com/OpenLayers-on-Windows-Mobile-6-5-td3892956.html#a3892956
> but my preference and the client’s one is to use IE Mobile.
> Is OL working on newer versions of IE Mobile or have I to find a
solution,
> maybe changing OL code.
> Thanks in advance.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100304/3417bcfb/attachment.html
More information about the Dev
