[OpenLayers-Dev] Right Mouse click for WMSGetFeatureInfo
Cédric Moullet cedric.moullet at camptocamp.com
Wed Mar 17 17:48:30 EDT 2010
Yep. This gave me goos ideas to solve the problem in the following way:
            this.handleRightClicks = true;
            this.handler = new OpenLayers.Handler.Click(this, {
                rightclick: this.getInfoForClick
                "single": true
Cédric
2010/3/17 Eric Lemoine <eric.lemoine at camptocamp.com>
> 2010/3/17 Eric Lemoine <eric.lemoine at camptocamp.com>:
> > 2010/3/17 Cédric Moullet <cedric.moullet at camptocamp.com>:
> >> Hi,
> >> I'd like to have the OpenLayers.Control.WMSGetFeatureInfo working on the
> >> right mouse click instead of the left mouse click.
> >> I tried to modify it in the following way
> http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js#L195
> >>                 {rightclick: this.getInfoForClick},
> >> this.handlerOptions.click || {});
> >> But without success. Could you give me a hint in order to support right
> >> mouse click with this control ?
> > you also need double:true in the handler options. This can be set by
> > providing the following in the control options:
> >    handlerOptions: {
> >        click: {
> >            "double": true,
> >            "single": false
> > Then it should work.
> > But I think the control should do
> >    click: this.getInfoForClick,
> > }, this.handlerOptions.click || {});
> > so that providing appropriate handler options to the could would
> > suffice to make it work on rightclick.
> Sorry I mixed up "double" and "rightclick". It's a bit late here! I
> hope you get the idea.
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
Geospatial Director Camptocamp SA
Cédric Moullet
PSE A
CH-1015 Lausanne
www.camptocamp.com  / www.mapfish.org / twitter.com/cedricmoullet /
mapfishblog.blogspot.com/
+41 79 759 69 83 (mobile)
+41 21 619 10 21 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100317/9043fe27/attachment.html
More information about the Dev mailing list
