[OpenLayers-Dev] Right Mouse click for WMSGetFeatureInfo
Cédric Moullet cedric.moullet at camptocamp.com
Wed Mar 17 18:36:27 EDT 2010
Finally, with the great help of Eric, a patch has been created:
http://trac.openlayers.org/ticket/2528
<http://trac.openlayers.org/ticket/2528>Cédric
2010/3/17 Cédric Moullet <cedric.moullet at camptocamp.com>
> Yep. This gave me goos ideas to solve the problem in the following way:
>             this.handleRightClicks = true;
>             this.handler = new OpenLayers.Handler.Click(this, {
>                  rightclick: this.getInfoForClick
>                 "single": true
> Cédric
> 2010/3/17 Eric Lemoine <eric.lemoine at camptocamp.com>
>> 2010/3/17 Eric Lemoine <eric.lemoine at camptocamp.com>:
>> > 2010/3/17 Cédric Moullet <cedric.moullet at camptocamp.com>:
>> >> Hi,
>> >> I'd like to have the OpenLayers.Control.WMSGetFeatureInfo working on
>> the
>> >> right mouse click instead of the left mouse click.
>> >> I tried to modify it in the following way
>> http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js#L195
>> >>                 {rightclick: this.getInfoForClick},
>> >> this.handlerOptions.click || {});
>> >> But without success. Could you give me a hint in order to support right
>> >> mouse click with this control ?
>> > you also need double:true in the handler options. This can be set by
>> > providing the following in the control options:
>> >    handlerOptions: {
>> >        click: {
>> >            "double": true,
>> >            "single": false
>> > Then it should work.
>> > But I think the control should do
>> >    click: this.getInfoForClick,
>> > }, this.handlerOptions.click || {});
>> > so that providing appropriate handler options to the could would
>> > suffice to make it work on rightclick.
>> Sorry I mixed up "double" and "rightclick". It's a bit late here! I
>> hope you get the idea.
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
> Geospatial Director Camptocamp SA
> Cédric Moullet
> PSE A
> CH-1015 Lausanne
> www.camptocamp.com  / www.mapfish.org / twitter.com/cedricmoullet /
> mapfishblog.blogspot.com/
> +41 79 759 69 83 (mobile)
> +41 21 619 10 21 (direct)
> +41 21 619 10 10 (centrale)
> +41 21 619 10 00 (fax)
Cédric Moullet
PSE A
CH-1015 Lausanne
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100317/10c8b3b6/attachment.html
More information about the Dev mailing list
