[OpenLayers-Dev] Map event confusion
Marc Jansen
jansen at terrestris.de
Fri Mar 26 08:47:28 EDT 2010
Hi all,
so do you all think I should open up a ticket with milestone 2.10
including a patch that does
* leave the events in the EVENT_TYPES array as they currently are
* but changes the documentation to not reference the events
o addmarker,
o removemarker,
o clearmarkers,
o dragstart,
o dragend,
o drag,
o popupopen,
o popupclose anymore?
* should I add yet another ticket to remove the unneeded events in 3.0?
What do you think? I am willing to provide a patch for the above ticket.
Regards and thanks for your opinions,
Marc
Stephen Woodbridge schrieb:
> Christopher Schmidt wrote:
>> On Thu, Mar 25, 2010 at 03:32:36PM -0600, Tim Schaub wrote:
>>> Marc Jansen wrote:
>>>> Hi devs,
>>>> I am rather confused about the documentation about map-events. Is it
>>>> right that
>>>> * addmarker,
>>>> * removemarker,
>>>> * clearmarkers,
>>>> * dragstart,
>>>> * dragend,
>>>> * drag
>>>> are defined but never get triggered?
>>>> If so, they should IMHO be removed from the EVENT_TYPES-array and the
>>>> documentation for that.
>>> The problem with removing things from the EVENT_TYPES array is that
>>> there could be applications that have subscribers for them and use
>>> map.events to publish.
>>> If we remove those entries, those applications break.
>>> I know this is silly. You are right to point out that there is little
>>> sense and lots of confusion in having them.
>>> Our safest bet is to mark them as unused and remove them in 3.0. If
>>> others think the caution is not needed, I wouldn't be opposed to
>>> removing them.
>> In general, I'm supportive of any changes that make things simpler which
>> means that applications that did not throw errorrs in earlier releases will
>> continue to not throw errors in future releases.
>> In this particular case, it's hard to imagine that someone has written
>> code that specifically registers for an event that doesn't do anything.
>> With sufficient documentation, I'd be willing to change the code to not
>> have those events. However, since events (unlike methods) are not actually
>> in existence in the Natural Docs except if they're documented, I think
>> it would be equally successful -- for anyone who isn't actually digging
>> into the code itself, a fact that describes more and more of our users --
>> to just not document those events. At that point, the events simply
>> 'disappear' from the docs completely without any other work on our
>> part.
>> -- Chris
> Chris, et al,
> I can appreciate this sentiment, I think there are a lot of "casual"
> users that will not dig into the code and in those cases, if it is not
> in the docs then the problem does indeed go away. But there are a small
> but healthy number of "coders" who are trying to do more with OpenLayers
> like Marc, myself and others I'm sure that do dig into the code and
> spend a lot of time chasing our tails, aka: learning? :) because we try
> something like an event that never gets triggered and then scratch our
> heads for a while trying to figure out why. We eventually do figure it
> out or ask and get help. I would like to see doc that better explains
> what events exist and what gets passed to them. I have also noticed that
> there is a trend to move away from callbacks, which were somewhat better
> documented, in favor of using events (or maybe I'm mistaken) and some
> objects say register for such and such event to get notified when
> something happens, but there is no additional information as to what is
> passed to the event, etc.
> Regardless, I'm loving OL and continued to be impressed by how much is
> built into OL and how easy OL is to extend once I can get my head to
> think about the problem in in the right way.
> Thanks all and best regards,
> -Steve
>>> Tim
>>>> Please ignore the mail if I missed something fundamental (but please
>>>> enlighten me where these events are triggered)
>>>> Regards,
>>>> Marc
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>>> Tim Schaub
>>> OpenGeo - http://opengeo.org
>>> Expert service straight from the developers.
>>> Dev mailing list
> Dev mailing list
More information about the Dev
