[OpenLayers-Dev] Map event confusion
Stephen Woodbridge woodbri at swoodbridge.com
Fri Mar 26 11:07:05 EDT 2010
I think that would be reasonable, I'm not sure I have a vote, but your
proposal has my support.
-Steve
Marc Jansen wrote:
> Hi all,
> so do you all think I should open up a ticket with milestone 2.10
> including a patch that does
>     * leave the events in the EVENT_TYPES array as they currently are
>     * but changes the documentation to not reference the events
>           o addmarker,
>           o removemarker,
>           o clearmarkers,
>           o dragstart,
>           o dragend,
>           o drag,
>           o popupopen,
>           o popupclose anymore?
>     * should I add yet another ticket to remove the unneeded events in 3.0?
> What do you think? I am willing to provide a patch for the above ticket.
> Regards and thanks for your opinions,
> Marc
> Stephen Woodbridge schrieb:
>> Christopher Schmidt wrote:
>>> On Thu, Mar 25, 2010 at 03:32:36PM -0600, Tim Schaub wrote:
>>>> Marc Jansen wrote:
>>>>> Hi devs,
>>>>> I am rather confused about the documentation about map-events. Is it
>>>>> right that
>>>>>     * addmarker,
>>>>>     * removemarker,
>>>>>     * clearmarkers,
>>>>>     * dragstart,
>>>>>     * dragend,
>>>>>     * drag
>>>>> are defined but never get triggered?
>>>>> If so, they should IMHO be removed from the EVENT_TYPES-array and the
>>>>> documentation for that.
>>>> The problem with removing things from the EVENT_TYPES array is that
>>>> there could be applications that have subscribers for them and use
>>>> map.events to publish.
>>>> If we remove those entries, those applications break.
>>>> I know this is silly.  You are right to point out that there is little
>>>> sense and lots of confusion in having them.
>>>> Our safest bet is to mark them as unused and remove them in 3.0.  If
>>>> others think the caution is not needed, I wouldn't be opposed to
>>>> removing them.
>>> In general, I'm supportive of any changes that make things simpler which
>>> means that applications that did not throw errorrs in earlier releases will
>>> continue to not throw errors in future releases.
>>> In this particular case, it's hard to imagine that someone has written
>>> code that specifically registers for an event that doesn't do anything.
>>> With sufficient documentation, I'd be willing to change the code to not
>>> have those events. However,  since events (unlike methods) are not actually
>>> in existence in the Natural Docs except if they're documented, I think
>>> it would be equally successful -- for anyone who isn't actually digging
>>> into the code itself, a fact that describes more and more of our users --
>>> to just not document those events. At that point, the events simply
>>> 'disappear' from the docs completely without any other work on our
>>> part.
>>> -- Chris
>> Chris, et al,
>> I can appreciate this sentiment, I think there are a lot of "casual"
>> users that will not dig into the code and in those cases, if it is not
>> in the docs then the problem does indeed go away. But there are a small
>> but healthy number of "coders" who are trying to do more with OpenLayers
>> like Marc, myself and others I'm sure that do dig into the code and
>> spend a lot of time chasing our tails, aka: learning? :) because we try
>> something like an event that never gets triggered and then scratch our
>> heads for a while trying to figure out why. We eventually do figure it
>> out or ask and get help. I would like to see doc that better explains
>> what events exist and what gets passed to them. I have also noticed that
>> there is a trend to move away from callbacks, which were somewhat better
>> documented, in favor of using events (or maybe I'm mistaken) and some
>> objects say register for such and such event to get notified when
>> something happens, but there is no additional information as to what is
>> passed to the event, etc.
>> Regardless, I'm loving OL and continued to be impressed by how much is
>> built into OL and how easy OL is to extend once I can get my head to
>> think about the problem in in the right way.
>> Thanks all and best regards,
>>    -Steve
>>>> Tim
>>>>> Please ignore the mail if I missed something fundamental (but please
>>>>> enlighten me where these events are triggered)
>>>>> Regards,
>>>>> Marc
>>>>> _______________________________________________
>>>>> Dev mailing list
>>>>> Dev at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/dev
>>>> Tim Schaub
>>>> OpenGeo - http://opengeo.org
>>>> Expert service straight from the developers.
>>>> Dev mailing list
>> Dev mailing list
> Dev mailing list
More information about the Dev mailing list
