[OpenLayers-Dev] 3 failing tests in Safari
Christopher Schmidt crschmidt at metacarta.com
Tue Mar 30 15:58:39 EDT 2010
On Tue, Mar 30, 2010 at 09:43:27PM +0200, Andreas Hocevar wrote:
> On 2010-03-30 21:18 , Bart van den Eijnden wrote:
> > Hi list,
> > we have 3 failing tests in Safari, does anyone know if these are known
> > issues or if they are fixable (before I even attempt)? TIA.
> > Control/PanZoom.html:
> > test_Control_PanZoom_control_events planned 35 assertions but got 1;
> > fail 1 ok 0
> > fail unable to open window for Control/PanZoom.html
> This one is just because popup windows are blocked on your Safari.
> For the others, I don't know.
The others are longstanding issues, and existed in the 2.8 release. They
should not block the 2.9 release.
-- Chris
> -Andreas.
> > Format/ArcXML.html:
> > test_Format_ArcXML_parseerror fail 1 ok 0
> > fail parsing failed to fail
> > Format/ArcXML/Features.html:
> > test_parseerror fail 1 ok 0
> > fail reading didn't fail
> > Best regards,
> > Bart
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Dev mailing list
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
