[OpenLayers-Dev] Two annoyances in the OpenLayers build.
Eric Lemoine eric.lemoine at camptocamp.com
Wed May 5 02:00:55 EDT 2010
On Wednesday, May 5, 2010, Phil Scadden <p.scadden at gns.cri.nz> wrote:
> 1/ gears_init.js - when using firebug, it ALWAYS breaks at this point
> because there is a
> try
>    ..do IE stuff
> except
> instead of
>       if (window.ActiveXObject) {
>       do IE stuff.
> I have changed this in my version so avoid this stupid break.
gears_init.js comes from Gears so I'd be a bit reluctant to modify it.
I'm wondering if there are other ways to address the issue you're
seeing.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
