[OpenLayers-Dev] OpenLayers.Strategy.Cluster and attributive comparisons
Eric Lemoine eric.lemoine at camptocamp.com
Mon Oct 4 13:09:42 EDT 2010
On Monday, October 4, 2010, Marc Jansen <jansen at terrestris.de> wrote:
> Hi list,
> the Cluster strategy decides whether two features should be grouped in a cluster and uses the relative distance of the features to do so. Nearby features are clustered, and features apart from each other are left untouched.
> In a recent project we had the need to extend this behaviour, so that the Cluster strategy should look at the attributes of the features too, when deciding on clustering: only nearby features that shared an attribute should be clustered, otherwise, they should be left alone.
> Imagine a situation where you have features with an attribute "klasse" that groups the features attributively. In the clustered map you only want Clusters of the same "klasse".
> In our case we could solve it using different layers (requested according to their "klasse") and each had their own Cluster-strategy.
> While we were refactoring that code a little bit we came up with the idea of new Cluster-subtypes: the very simple OpenLayers.Strategy.AttributeCluster and the more elaborate OpenLayers.Strategy.RuleCluster:
> OpenLayers.Strategy.AttributeCluster = OpenLayers.Class(OpenLayers.Strategy.Cluster, {
>      * the attribute to use for comparison
>     attribute: null,
>      * Method: shouldCluster
>      * Determine whether to include a feature in a given cluster.
>      * Parameters:
>      * cluster - {<OpenLayers.Feature.Vector>} A cluster.
>      * feature - {<OpenLayers.Feature.Vector>} A feature.
>      * Returns:
>      * {Boolean} The feature should be included in the cluster.
>     shouldCluster: function(cluster, feature) {
>         var cc = cluster.geometry.getBounds().getCenterLonLat();
>         var fc = feature.geometry.getBounds().getCenterLonLat();
>         var distance = (
>             Math.sqrt(
>                 Math.pow((cc.lon - fc.lon), 2) + Math.pow((cc.lat - fc.lat), 2)
>             ) / this.resolution
>         var cc_attrval = cluster.cluster[0].attributes[this.attribute];
>         var fc_attrval = feature.attributes[this.attribute];
>         return (distance <= this.distance && cc_attrval === fc_attrval);
>     CLASS_NAME: "OpenLayers.Strategy.AttributeCluster"
> OpenLayers.Strategy.RuleCluster = OpenLayers.Class(OpenLayers.Strategy.Cluster, {
>      * the rule to use for comparison
>     rule: null,
>      * Parameters:
>      * Returns:
>         var distance = (
>             Math.sqrt(
>             ) / this.resolution
>         return (distance <= this.distance && this.rule.evaluate(cluster.cluster[0]) && this.rule.evaluate(feature));
>     CLASS_NAME: "OpenLayers.Strategy.RuleCluster"
> Usage Examples:
>         // cluster only features that have 'klasse' < 3
>         new OpenLayers.Layer.Vector('Vektorlayer 1', {
>             strategies: [new OpenLayers.Strategy.Fixed(), new OpenLayers.Strategy.RuleCluster({
>                 rule: new OpenLayers.Rule({
>                     // a rule contains an optional filter
>                     filter: new OpenLayers.Filter.Comparison({
>                         type: OpenLayers.Filter.Comparison.LESS_THAN,
>                         property: "klasse",
>                         value: 3
>             protocol: new OpenLayers.Protocol.HTTP({
>                 url: "../data/data_001.json",
>                 format: new OpenLayers.Format.GeoJSON()
>         // cluster only features that are nearby and have the same "klasse"
>         new OpenLayers.Layer.Vector('Vektorlayer 2', {
>             strategies: [new OpenLayers.Strategy.Fixed(), new OpenLayers.Strategy.AttributeCluster({
>                     attribute: 'klasse'
>                 url: "../data/data_002.json",
> We are unsure whether this might be of interest to anybody. If so, we would be happy to provide patches for OpenLayers. This code currently has no tests, and there is room for optimization (the comparison of attributes is probably faster computed than the distance e.g.)
> Please share your thoughts on this and tell us of alternatives we may have missed, or drawbacks of the outlined approach.
Your approach looks good to me, and it demonstrates well how the
cluster strategy can be extended for specific needs. To me it'd make
sense to have this code in a cluster-strategy-extended.html example or
something.
My 2 cents,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
