[OpenLayers-Dev] OpenLayers.Strategy.Cluster and attributive comparisons
Eric Lemoine eric.lemoine at camptocamp.com
Thu Oct 7 03:17:32 EDT 2010
On Thu, Oct 7, 2010 at 9:15 AM, Eric Lemoine
<eric.lemoine at camptocamp.com> wrote:
> On Thu, Oct 7, 2010 at 9:14 AM, Eric Lemoine
>> On Wed, Oct 6, 2010 at 2:11 PM, Marc Jansen <jansen at terrestris.de> wrote:
>>> Hi Eric,
>>> thanks for your feedback.
>>> Attached is an example that shows the usage and the benefits from the custom
>>> classes. I would be happy if this could be included in the OpenLayers
>>> examples.
>> This is really nice!
>> I modified your example a bit to make the extended classes rely on
>> their parents' shouldCluster method, this is to avoid code
>> duplication. I also renamed the files from cluster-strategy-extend.*
>> to strategy-cluster-extended.*, to be consistent with the other
>> cluster examples.
>> Tell me if these changes are fine by you.
>> Thank you Marc.
> The files are attached.
Argh I'm sorry, the .js file didn't get attached. Retrying. Hope this
is fine this time.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20101007/10bb4233/strategy-cluster-extended-0001.html
Type: application/x-javascript
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20101007/10bb4233/strategy-cluster-extended-0001.js
More information about the Dev mailing list
