[OpenLayers-Dev] Dragging like a route
1againstspamm777 at abwesend.de 1againstspamm777 at abwesend.de
Mon Oct 11 03:09:53 EDT 2010
Hi list,
I drag points in my map und connect the points with some lines (snapping feature). Ok, that works fine. But now i want to move points and lines together with the dragging feature. How can i do this? I doenst want to drag points and lines seperatly. It should be like a routing plan. I change the starting point and the line change the position too.
Any ideas or parts of a solution?
thanks in advance,
againstspam
Neu: GMX De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
Jetzt De-Mail-Adresse reservieren: http://portal.gmx.net/de/go/demail
More information about the Dev mailing list
