[OpenLayers-Dev] ProxyHost
Alexandre Dube
adube at mapgears.com
Mon Oct 18 08:32:13 EDT 2010
Edit the file and see if the host you're accessing is in the array
"allowedHosts".
Regards,
Alexandre
On 10-10-17 12:21 AM, Mohammed Rashad wrote:
> How to set ProxyHost.
> I had downloaded the proxy.cgi from openlayers trac and without
> no modification i copied it to /usr/lib/cgi-bin/proxy.cgi
> I am behind a proxy and http://proxy.rashadkm.in port=8080
> How to set the proxy if i am behind the above proxy.
> OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
> my firebug output was
> Access to restricted URI denied" code: "1012
> http://openlayers.org/api/OpenLayers.js
> Line 1188
> What is wrong? . Please correct me if I am wrong.
> Anyone please help
> Rashad
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Alexandre Dubé
Mapgears
www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20101018/7f074fca/attachment.html
More information about the Dev
