[OpenLayers-Dev] Problem with popup in MapServer layer
florencia.bujan florita026 at gmail.com
Wed Oct 20 12:24:10 EDT 2010
I am from Uruguay and sorry because my english is very poor.
I have a problem with a popup. I want to show a information from postgis
database (geodatabase) when the user mouse over a line in a mapserver layer
(in this case line layer).
I am investigate a lot of days and I work with a lot of examples, but I
can't do that.
This is possible? Can you help me?...
I don't know if I am in the correct way but the last example is these (I'm
base on this example:
http://dev4.mapgears.com/bdga/options-by-zoom-and-highlight-bdga.html)
Thanks a lot!!
Regards,
Florencia
***** .MAP CODE ******
MAP
        NAME GISADP
        SIZE 700 700
        STATUS ON
        EXTENT -63.4393 -33.974 -48.1827 -32.0861
        FONTSET "misc/fonts/fonts.txt"
        SYMBOLSET "misc/symbols/symbols.sym"
        IMAGECOLOR 255 255 255
        UNITS dd
        WEB
                METADATA
                        "wms_title"           "ADP - Sistema de Información
Geográfica"
                        "wms_onlineresource"
"http://192.168.1.154/cgi-bin/mapserv.exe?map=../htdocs/Florencia/GISManager/flor.map&"
                        "wms_srs"       "EPSG:4326"
                        "wms_transparent"       "true"
                        "labelcache_map_edge_buffer" "-10"
                        "wfs_namespace_prefix"               "feature"
           	        "wfs_namespace_uri"
"http://192.168.1.154/"
                END
        END
        PROJECTION
                "init=EPSG:4326"
        END
        LAYER
                CONNECTIONTYPE postgis
                NAME "Terrazas"
                STATUS ON
                CONNECTION "user=** password=** dbname=** host=**"
                DATA "the_geom from (SELECT l.* from terrazas l, campos c
WHERE c.id=l.idcampo) as terrazas using unique gid using SRID=-1"
                TYPE LINE
                CLASS
                        NAME "Terrazas"
                        STYLE
               SIZE 4
               COLOR 0 192 255
               SYMBOL "BigLine"
          END
                END
                TOLERANCE 20
        END
END
******* OPENLAYERS CODE in init function **************
OpenLayers.Feature.Vector.style['default']['strokeWidth'] = '2';
 var oRegStyleMap = new OpenLayers.StyleMap({
            strokeColor: "black",
            strokeWidth: 2,
            strokeOpacity: 1,
            fillOpacity: 0.8
 var aRegColor = {
            '01': {fillColor:"purple" },
            '02': {fillColor:"blue" },
            '03': {fillColor:"yellow" },
            '04': {fillColor:"red" },
            '05': {fillColor:"#ffa500" }, //orange
            '06': {fillColor:"red" },
            '07': {fillColor:"purple" },
            '08': {fillColor:"blue" },
            '09': {fillColor:"green" },
            '10': {fillColor:"#ffa500" },
            '11': {fillColor:"#ffa500" },
            '12': {fillColor:"green" },
            '13': {fillColor:"purple" },
            '14': {fillColor:"#ffa500" },
            '15': {fillColor:"yellow" },
            '16': {fillColor:"green" },
            '17': {fillColor:"blue" }
oRegStyleMap.addUniqueValueRules("default", "res_co_reg", aRegColor);
var szBDGAMapPath = "../htdocs/GISManager/flor.map";
var szHost = "http://localhost/";
        var szMSURL = szHost+"cgi-bin/mapserv.exe";
        oMap = new OpenLayers.Map( 'map');
        var wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
                "http://vmap0.tiles.osgeo.org/wms/vmap0",
                {layers: 'basic'} );
        oMap.addLayers([wms]);
        oMap.setCenter(new OpenLayers.LonLat(-57.5, -34), 9);
        var layerLocal = new OpenLayers.Layer.MapServer("Terrazas",
                                stringMapa,
                {layers:'Terrazas', format:'image/png'},
                {isBaseLayer:false, visibility:true, opacity:0.5,
transparent:true, displayInLayerSwitcher: false }
        //oMap.addLayer(layerLocal);
        olWFSReg = new OpenLayers.Layer.Vector("GISADP", {
            styleMap: oRegStyleMap,
            strategies: [
                new OpenLayers.Strategy.OptionsByZoom({
                    optionsByZoom: {
                        0: {featureType: "Terrazas"},
                        1: {featureType: "Terrazas"},
                        2: {featureType: "Terrazas"},
                        3: {featureType: "Terrazas"}
                    defaultOptions: {featureType: "Terrazas"}
                new OpenLayers.Strategy.BBOX()
            protocol: new OpenLayers.Protocol.WFS({
                version:       "1.0.0",
                url:           stringMapa,
                featureType:   "Terrazas",
                srsName:       "EPSG:4326",
                featureNS:     "http://localhost/",
                geometryName:  "the_geom",
                schema:
szMSURL+"?service=WFS&version=1.0.0&request=DescribeFeatureType&TypeName=Terrazas"
        oMap.addLayers([ olWFSReg ]);
        var highlighter = new OpenLayers.Control.HighlightFeature({
            layer: olWFSReg,
            displayPopup: true,
            popupOffset: {
                'left': 45,
                'right': 0,
                'top': 5
            popupTitle: "Province information",
            popupSize: new OpenLayers.Size(200,225),
            style:{
                strokeWidth: 2,
                strokeOpacity: 0.8,
                fillOpacity: 0.5,
                fillColor: "black"
        oMap.addControl(highlighter);
        highlighter.activate();
        oMap.addControl(new OpenLayers.Control.Navigation());
        oMap.addControl(new OpenLayers.Control.Scale($('scale')));
        oMap.addControl(new OpenLayers.Control.LayerSwitcher());
        oMap.addControl(new OpenLayers.Control.PanZoomBar());
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-with-popup-in-MapServer-layer-tp5655613p5655613.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
