[OpenLayers-Dev] save vector
Bart van den Eijnden bartvde at osgis.nl
Fri Oct 22 12:46:16 EDT 2010
check the example wfs-protocol-transactions.html.
You will need to use e.g. Geoserver as a transactional WFS-T on your data. I would advise not to use shapefiles for WFS-T, but e.g. PostGIS.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Oct 22, 2010, at 6:36 PM, Mohammed Rashad wrote:
> how to save a openlayers.Layer.vector?
> I had created a vector Layer called Editable and drawn some featurers on it. some polygons and points.
> How can I save the vector data into a shapefile or any other valid vector dataformats?
> Rashad
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
