[OpenLayers-Dev] how to view saved feature?
Mohammed Rashad mohammedrashadkm at gmail.com
Fri Oct 22 15:04:05 EDT 2010
On Sat, Oct 23, 2010 at 12:24 AM, Steven Ottens <steven at minst.net> wrote:
> Hi,
> From the series of e-mails I gather that you try to draw something in
> openlayers and then save that drawing to be able to use it somewhere else.
> Also I've got the feeling that you are not familiar with WFS and/or
> openlayers. However your e-mails are very short and don't provide a lot of
> context so I could be wrong.
> You are right.
> To answer your questions: yes many people have succeeded to use openlayers
> with WFS
> http://dev.openlayers.org/releases/OpenLayers-2.10/examples/wfs-protocol-transactions.html
Please check the link you given. only a google map is shown without any
controls :(
I used the example and it is saving but when I reload its not showing the
drawings.
I am not familiar with WFS. Can you help me . I can manage to set a WFS
server using UMN Mapserver. now I need to know whats next after setting a
WFS.
Will you please brief the steps I need to follow for acheiving my aim which
you already know (draw some drawing and save the features to postgis)
Please help me if you can...
being the obvious example. You need a WFS server to be able to save features
> and they are stored on the WFS server, commonly in a database. Once it is
> stored in the database you can use it in any application which can connect
> with the database (eg. qgis, udig). If you want to create a shapefile out of
> it, you most likely need to export the data from the database to shapefile,
> either with tools from the database (pgsql2shp) or another application (eg
> qgis).
> In general you probably want to read up on WFS, Geoserver and previous
> emails on the openlayers-list on WFS. Also you might want to do more
> research before sending single line emails to a mailing list :)
> good luck
> Steven
> On Oct 22, 2010, at 8:37 PM, Mohammed Rashad wrote:
> > How to view the saved features saved using
> wfs-protocol-transactions.html?
> > Where it is saved? How to use the saved data?
> > Rashad
> > Dev mailing list
> > Dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Rashad
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20101023/04835317/attachment.html
More information about the Dev mailing list
