[OpenLayers-Dev] Re: Bug in the positioning of popups "Anchored", "Framed" and "FramedCloud" using argument "anchor".
Roald de Wit list at rdewit.net
Sun Oct 24 22:49:29 EDT 2010
Hi Xavier,
Thanks for investigating. I'll look into this this week and if I can't
find a suitable fix, then I guess reverting the change will be the best
option (as you suggested).
Regards,
Roald
On 21/10/10 01:54, Xavier Mamano (jorix) wrote:
> Hi Roald,
> The example "popupMatrixVector.html" was incorrect anchor, see
> http://trac.osgeo.org/openlayers/ticket/2870#comment:2
> I think there's a bug in Popup.Anchored.js
> Regards,
> Xavier
> Roald de Wit-3 wrote:
>>    Hi Xavier,
>> It looks like I'm responsible for that one... My apologies for causing
>> problems. I have to admit that I did not test these changes with
>> OpenLayers.Layer.Markers but with OpenLayers.Layer.Vector.
>> After having looked into the issue, I think (and hope) that we can keep
>> the changes in that revision and, if possible, fix the issue for markers.
>> Some arguments against reverting the change:
>> - It does indeed fix a problem where a popup related to a vector feature
>> did not use the anchor as it should
>> - Markers are sort of 'not done'. Rule is to use vectors. (see [1] for
>> example)
>> - createPopup is not an API property (not sure if that was intentional)
>> I rewrote popupMatrix.html to work pretty much the same but then for
>> vector layers (attached to the #2870). Maybe it's a good idea to replace
>> the old one with this one (provided that it's bug-free)?
>> Please let me know if this solves the issue for you. If not, I'm sure it
>> should not be too hard to make it work for both Vector and Marker
>> features and I'm happy to investigate that.
>> Regards, Roald
>> [1]
>> http://osgeo-org.1803224.n2.nabble.com/Markers-vs-Features-td1828248.html
>> On 11/10/10 19:25, Xavier Mamano (jorix) wrote:
>>> see http://trac.osgeo.org/openlayers/ticket/2870
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
