[OpenLayers-Dev] when moving/dragging a feature the moveend event has zoomChanged set to true.
Eric Lemoine eric.lemoine at camptocamp.com
Thu Sep 2 00:46:05 EDT 2010
On Thursday, September 2, 2010, MostlyBaldEagle <MostlyBaldEagle at shaw.ca> wrote:
> When moving/dragging a feature the moveend event has zoomChanged set to true.
> This doesn't seem to be correct as no zooming has happened.
> Is this a known problem in the current release?
I guess not. Do you have a test case demonstrating this?
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
