[OpenLayers-Dev] Bug in Control.Measure: Using freehand, last measure is less than the correct measure.
Xavier Mamano (jorix) xavier.mamano at gmail.com
Fri Sep 3 17:59:09 EDT 2010
This is a problem that the end user will only happen when makes measurements
using freehand (by pressing the Shift key)
See: http://trac.openlayers.org/ticket/2820 for tests and patch.
For the ticket I left Milestone 2.11
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Bug-in-Control-Measure-Using-freehand-last-measure-is-less-than-the-correct-measure-tp5497114p5497114.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
