[OpenLayers-Dev] DOM manipulation adapters
Volker Mische volker.mische at gmail.com
Fri Sep 10 08:24:51 EDT 2010
Hi devs,
for the OL 3.0 refactor the util class should get refactored. Much of
this functionality is already available in the common JS libs. To make
it easier to find out which lib contains what functionality you can have
a look at the test for Taskpeed [1].
[1] http://github.com/phiggins42/taskspeed/tree/master/tests/
Cheers,
  Volker
More information about the Dev mailing list
