[OpenLayers-Dev] Maximum number of tiles requested
Xurxo Mendez xmendez at udc.es
Mon Sep 13 06:13:36 EDT 2010
Hi all,
in Firefox 3.x the limits are these (you can see/modify them typing
*about:config* in the URL bar):
network.http.max.connections (default is 30)
network.http.max.connections-per-server (default is 15)
network.http.max.persistent-connections-per-proxy (default is 8)
network.http.max.persistent-connections-per-server (default is 6)
Un saludo.
Xurxo Méndez Pérez
Runner for Android:
http://www.androidrunner.com
http://blog.androidrunner.com
2010/9/13 DGIS Devels <webgisdesarrollo at gmail.com>
> Thanks Peter. We didn't know this limit is so small. I'm not sure but in
> Firefox seems to be of 4 parallel requests, isn't?
> 2010/9/10 Peter Körner <osm-lists at mazdermind.de>
> Am 10.09.2010 14:42, schrieb DGIS Devels:
>>  Is the number of tiles requested simultaneously limited in OpenLayers? I
>>> would like to know how long I have to wait (timeout) to have a whole map
>>> with a high number of tiles.
>> Most browsers have a hard-coded limit of 2 parallel Requests per Domain to
>> avoid flooding servers with requests.
>> The limit is per Domain, not per IP, which is why you can trick around
>> this limit by using multiple domains to point to your tile-server (
>> a.tile.myserver.net, b.tile.myserver.net, c.tile.myserver.net).
>> If is, for example, done on osm.org:
>> http://www.openstreetmap.org/openlayers/OpenStreetMap.js
>> Peter
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100913/9504e0fa/attachment.html
More information about the Dev mailing list
