[OpenLayers-Dev] The domain for sale "freemap.in" is used in 5examples.
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Mon Sep 13 09:35:58 EDT 2010
On Sep 13, 2010, at 9:31 AM, ext Schuyler Erle wrote:
> We can just change the domain on that server also; the server hasn't gone away, just the domain.
But the content has been gone for a while? I never set that stuff back up after the server
disappeared originally, and I don't see it on the freemap server now, unless you
put it in some weird place. Probably easier just to point to other available
services (or set a new one up) than try to recover it; there was never anything
that complex there, other than the Boston Freemap.
-- Chris
> SDE
> (sent from my mobile)
> -----Original Message-----
> From: <christopher.schmidt at nokia.com>
> Sender: openlayers-dev-bounces at lists.osgeo.org
> Date: Mon, 13 Sep 2010 13:05:55
> To: <xavier.mamano at gmail.com>
> Cc: <dev at openlayers.org>
> Subject: Re: [OpenLayers-Dev] The domain for sale "freemap.in" is used in 5
> 	examples.
> On Sep 12, 2010, at 11:37 AM, ext Xavier Mamano (jorix) wrote:
>> Hi,
>> The domain for sale "http://freemap.in/" is used in the following examples:
>> "getfeatureinfo.html", "google-reproject.html", "gutter.html",
>> "projected-map.html" and "spherical-mercator.html"
> Good point. Thanks.
> I don't have a server available that is a good demonstration of:
> 1. Using a differently projected (not 4326 or 900913) map
> 2. A map which is affected significantly by gutters
> 3. A good GetFeatureInfo example.
> Does anyone have any suggestions/offers of what to use for these
> examples?
> I would assume that the third would be easy to set up against one
> of OpenGeo's demo servers; perhaps tschaub or ahocevar can comment
> on that.
> The google-reproject.html example should just go away, and removing
> the freemap.in layer from the Spherical Mercator example probably
> doesn't hurt either.
> -- Chris
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
