[OpenLayers-Dev] Question: Vector layer with draw & modify feature
Alexandre Dube adube at mapgears.com
Wed Sep 15 08:24:20 EDT 2010
Hi Moiz,
   The constructor of the control only takes 2 parameters [1] and you
give it 3.  This might be why it doesn't work.
Regards,
Alexandre
[1]
http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Control/ModifyFeature-js.html#OpenLayers.Control.ModifyFeature.OpenLayers.Control.ModifyFeature
On 10-09-15 05:32 AM, Moiz Bhukhiya wrote:
> Hi,
> I am using vector (polygon) layer with draw feature and modify
> feature. Let me explain first what I am trying to achieve. I want to
> draw rectangles(strict horizontally aligned) and after drawing it
> might require a little bit of modification but again it shouldn't lose
> its shape.
> Here is what I tried doing:
> polygonLayer = new OpenLayers.Layer.Vector("Capture Region",
> {displayInLayerSwitcher: true, reproject: true});
>         polyOptions = {sides: 4, snapAngle: 180, irregular: true};
> //To draw only rectangles
>         var pan = new OpenLayers.Control.Navigation({title: "Navigate"})
>         polygonControl = new
> OpenLayers.Control.DrawFeature(polygonLayer,
> OpenLayers.Handler.RegularPolygon,
>             {handlerOptions: polyOptions});
>         modify = new OpenLayers.Control.ModifyFeature(
>                 polygonLayer, {displayClass: "olControlModifyFeature",
> title: "Modify Features"},
>                 {mode: ~OpenLayers.Control.ModifyFeature.RESHAPE |
> OpenLayers.Control.ModifyFeature.RESIZE
>                 | OpenLayers.Control.ModifyFeature.DRAG }
>         var panel = new OpenLayers.Control.Panel({
>              displayClass: "olControlEditingToolbar"
>         panel.addControls([pan, polygonControl, modify]);
>         map.addControl(panel);
> The problem is it doesn't follow the modify feature modes I have
> defined. It allows reshaping and doesn't allow dragging and resizing.
> Another problem I have is when I define the displayClass for draw
> feature, it wouldn't let me draw rectangles that are horizontally
> aligned. To point your attention towards where I might be making a
> mistake, I am using OpenLayers.Handler.RegularPolygon to draw feature.
> Is that a problem?
> Thanks a lot for taking time to read my problem and I'd really
> appreciate if you could help me with any suggestions and ideas.
> Thanks!
> Moiz
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Alexandre Dubé
Mapgears
www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100915/b2775288/attachment.html
More information about the Dev mailing list
