[OpenLayers-Dev] [OpenLayers 3] code sprint summary, and request
for comments
Peter Robins
openlayers at peterrobins.co.uk
Sun Sep 19 05:37:26 EDT 2010
On 17 September 2010 12:33, Eric Lemoine <eric.lemoine at camptocamp.com> wrote:
> a projection. But, to be able to support
> new OpenLayers.Map({
> div: "map",
> layers: new OpenLayers.Layer.Google()
> center: [0, 0]
> we could introduce a kind of fallback mechanism, where the map gets
> the projection from the first layer (the one at index 0 in the layers
> array) when it has no projection itself.
this seems contradictory to me. On the one hand, you're saying that
all layers are equal, but then you're saying the first layer somehow
has priority - so all layers are equal, but some are more equal than
others :-)
I agree that it would be better to make things more flexible, and not
make the baselayer/overlay distinction compulsory. But this
distinction is surely useful, and ISTM that getting rid of it is going
too far the other way. It's surely a common use case that people want
to display some vectors over a fixed raster like Google. The raster
layer is only available in a limited number of
projections/resolutions, and the vectors have to adapt themselves to
that. So in this case the raster layer not the vector layer has to
determine the map projection/resolution. These 2 layers are not equal,
and I don't see the point in pretending they are. This is implicit in
your example above, but would it not be better to make it explicit by
distinguishing between the base/master/inflexible/whateverothername
layer and the overlay/flexible/whateverothername one?
Having said that, I agree that it would be nice to be able to combine
different layers with different projections in the same map, and be
able to toggle between them. For example, a walking route map in the
Pyrenees could enable the user to look at the French map in the French
projection for French sections, and to switch to the Spanish
map/projection for the Spanish sections. (It would also be a good
tutorial on how different projections represent the earth in different
ways.)
On the subject of layers, it would be nice to have a distinction
between source/server and OL layers. Google for example has several
different layers, and it would be nice to be able to set these up in a
layerswitcher control and allow the user to change between them
without the programmer having to set up a separate OL layer for each
one. The same applies to WMS servers, where it's common to have
different layers for road, rail, river etc. It would simplify things
if the programmer could just define 1 OL layer for this, and then have
the layerswitcher determine the LAYERS parameter. (Ok, I know this can
be done at the moment with custom code, but it would be nice if it
could be simple to set up.)
Another point about vectors would be that a vector source too might be
available in several different projections. Depending on
circumstances, it might be better to fetch the file in the new
projection if available rather than rely on the appropriate
transformation logic (proj or whatever) being present for those
particular projections. So a way to specify this layer as supporting
projections a and b, otherwise use transform().
As the EPSG has now set up a code for 'Google Mercator' (3857), ISTM
it would be better to use that and remove the fictitious 900913. Also,
get rid of the 'spherical mercator' param, which is inherent in the
projection and should not need to be specially defined.
More information about the Dev
