[OpenLayers-Dev] Re: TransformFeature control destroy function
seems to have a bug
Fabian Patzke (OL)
listensammler at patzi.de
Tue Sep 21 05:22:45 EDT 2010
Andreas Hocevar-2 wrote:
> what you are describing here can only happen if you "delete everything in
> the used vector layer" *before* you "deactivate the control".
That's true, that was my approach. I deleted everything first.
> If you have double-checked that you deactivate the control before removing
> the features from the layer and still see the issue, then please create a
> ticket with a test case or a minimal example that shows the problem.
> Regards,
> Andreas.
So this is my fault using a wrong sequence of actions. Maybe it should be
made a bit more clear somewhere that one has to follow a certain kind of
order to clear any digitize procedure? Because for me it was not obvious
that it is a fault to first empty and then deactivate and destroy controls.
Greetings,
Fabian
> On Sep 20, 2010, at 16:07 , Fabian Patzke (OL) wrote:
>> Hi, it seems that the TransformFeature control has a broken destroy
>> function
>> or maybe its just me doing something forbidden. When you try to destroy
>> the
>> control there can be an error in line 565. For me it happens when I do
>> the
>> following.
>> - start the map
>> - start using the TransformFeature control
>> - deactivate the control and delete everything in the used vector layer
>> (I
>> do this because I want a clear map after I used any kind of digi control)
>> - using TransformFeature.destroy() now throws an error, because there is
>> no
>> geometry in the box left.
>> shouldn't there be a kind of check if the box has no geometry?
>> If someone else thinks that is a bug and not me using it the wrong way, I
>> would create a ticket.
>> Greetings,
>> Fabian
>> I made this patch and it works for me:
>> Index: lib/OpenLayers/Control/TransformFeature.js
>> --- lib/OpenLayers/Control/TransformFeature.js (revision 10773)
>> +++ lib/OpenLayers/Control/TransformFeature.js (working copy)
>> @@ -561,12 +561,14 @@
>> destroy: function() {
>> var geom;
>> - for(var i=0; i<8; ++i) {
>> - geom = this.box.geometry.components[i];
>> - geom._handle.destroy();
>> - geom._handle = null;
>> - geom._rotationHandle && geom._rotationHandle.destroy();
>> - geom._rotationHandle = null;
>> + if (this.box.geometry != null) {
>> + for(var i=0; i<8; ++i) {
>> + geom = this.box.geometry.components[i];
>> + geom._handle.destroy();
>> + geom._handle = null;
>> + geom._rotationHandle && geom._rotationHandle.destroy();
>> + geom._rotationHandle = null;
>> this.box.destroy();
>> this.box = null;
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/TransformFeature-control-destroy-function-seems-to-have-a-bug-tp5550628p5550628.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Dev mailing list
View this message in context: http://osgeo-org.1803224.n2.nabble.com/TransformFeature-control-destroy-function-seems-to-have-a-bug-tp5550628p5553874.html
More information about the Dev
